Icauto's avatar
Icauto
Email alert Not going to work with GMAIL effective 3-31-2019
I use GMAIL for my email and the email alerts from my ReadyNAS 214. I received the following email from GMAIL:
Hello,
Although you don’t need to take any action, we wanted to let you know that the following third-party apps will no longer be able to access some data in your Google Account, including your Gmail content. This change will go into effect starting March 31, 2019.
ReadyNAS Email Notification
We are making this change as part of ongoing efforts to make sure your data is protected and private. These apps haven’t yet complied with our updated data privacy requirements announced on October 8, 2018.
You can always view, manage and remove apps you’ve given access to your account by visiting your Google Account.
Thanks,
The Google Accounts team
When you setup email alerts, you need to put in your google email credentials. Google is now notifying my the email alert feature does not comply with gmail requirements.
Is there going to be an update to the READYNAS so it conforms?
Thanks
  • StephenB's avatar
    I don't understand the title of your post, as it seems unrelated to the text.  Can you clarify?
    I also use gmail for notifications, and I haven't seen any email like yours from google. What firmware is your NAS running?
    • mopgcw's avatar
      mopgcw
      I received the same  notifications as  well;    running 6.95.
      • StephenB's avatar
        I believe it depends on whether your email alerts are using token auth or not (my setup isn't using token auth).
        Try signing out and then sign in again.
  • Icewaterhot's avatar
    Icewaterhot
    NETGEAR Employee Retired
    Hello Icauto ,
    Can you re-login again at email elert? It will be fine.
    Thanks,
    • Icauto's avatar
      Icauto
      Hello,
      I am running firmware 6.9.5 which the ReadyNAS says is the latest..
      • Icauto's avatar
        Icauto
        I do not know why the title of the post is:
        Random "hello test" notification from nighthawk app
        I had put in Email alert Not working with GMAIL effective 3-31-2019. I tried to change it but it wont change....
ProSupport for Business
