Doug6392
May 25, 2021Guide
Error: System volume root's usage is 81%.
I received this error this morning, and found some worthwhile previous discussion, especially from StephenB. I initiated an SSH connection and found the only very oversized file in root was "syslog". ...
- May 26, 2021
Doug6392 wrote:
Thanks for the quick reply. Sorry to be a pain, but how do I truncate the file?This should work:
echo -n > /var/log/syslog
Make sure you log in as root (using the NAS admin password). I am thinking your earlier attempt might have failed because you logged in as admin.
May 25, 2021Guru - Experienced User
Doug6392 wrote:
I initiated an SSH connection and found the only very oversized file in root was "syslog". Will clearing the log correct this? I probably haven't cleared the log, maybe since the unit was new.
You must have installed an app that includes rsyslog. syslog isn't part of the readynas application at all. So as far as the NAS is concerned, you certainly can truncate it.
FWIW, /var/log on my main NAS looks like this:
4.0K alternatives.log
2.7M apache2
108K apt
0 audit
28K btmp
0 clamav
4.0K dbbroker.log
144K dpkg.log
0 faillog
2.7M frontview
0 fsck
48M journal
20K lastlog
0 news
236K proftpd.log
860K proftpd.log.old
3.1M readynasd
1.1M samba
8.0K tallylog
804K wtmp
60M total
Doug6392
May 26, 2021Guide
Thanks for the quick reply. Sorry to be a pain, but how do I truncate the file? I tried removing it via basic Linux commands I found online but was not successful.
