Fishbones
Feb 05, 2011Tutor
Ethernet 1 connecting at 100Mbit only.
After a power cycle on a PRO Business eth0 will only connect at 100Mbit. Swapped cables, inspected and cleaned socket but no go. The NAS is connected to a GS108T switch. Log for eth0 after a reco...
PapaBear1
Feb 05, 2011Apprentice
A couple of things I would try:
1) Try connecting to the other port first.
If that did not work,
2) Test with a direct connection to a PC that has a gigabit ethernet port and see what the connection speed is.
