Fishbones
Feb 05, 2011Tutor
Ethernet 1 connecting at 100Mbit only.
After a power cycle on a PRO Business eth0 will only connect at 100Mbit. Swapped cables, inspected and cleaned socket but no go. The NAS is connected to a GS108T switch. Log for eth0 after a reco...
Fishbones
Feb 05, 2011Tutor
PapaBear wrote: I actually meant the other port on the Pro.
Failed to mention that i'm using both ports already... teaming.
eth1 will come up immediately at 1Gbit. eth0 will take about 10 seconds then come up at 100Mbit.
I have done a firmware re-install and also tried single port without teaming ... same problem. I'm beginning to suspect problems with the eth0 NIC.
Cheers.
