Fishbones
Feb 05, 2011Tutor
Ethernet 1 connecting at 100Mbit only.
After a power cycle on a PRO Business eth0 will only connect at 100Mbit. Swapped cables, inspected and cleaned socket but no go. The NAS is connected to a GS108T switch. Log for eth0 after a reco...
PapaBear1
Feb 05, 2011Apprentice
That would be my conclusion.
For a final verification you might want to try eth0 by itself, using the same cable and switch port that is currently connected to eth1.
