Fishbones
Feb 05, 2011Tutor
Ethernet 1 connecting at 100Mbit only.
After a power cycle on a PRO Business eth0 will only connect at 100Mbit. Swapped cables, inspected and cleaned socket but no go. The NAS is connected to a GS108T switch. Log for eth0 after a reco...
ahpsi1
Feb 09, 2011Tutor
Interesting the message appears to only involve the Yukon chipped NIC's. The 'downshift' can be 4 or two pair and at first blush would suggest a bad cable but you have already swapped that out. Only solution I found elsewhere was to install new NIC's :/
