Fishbones
Feb 05, 2011Tutor
Ethernet 1 connecting at 100Mbit only.
After a power cycle on a PRO Business eth0 will only connect at 100Mbit. Swapped cables, inspected and cleaned socket but no go. The NAS is connected to a GS108T switch. Log for eth0 after a reco...
Fishbones
Feb 10, 2011Tutor
alexofindy wrote: I had this problem and it was the cable; 1 GB is much fussier about cables than 100 MB. Though you say swapping cables was one of your first moves, be sure you're not swapping a bad cable for a bad cable, and that you're using a cable you know works at 1 GB.
Same cable on Ethernet Port 2 comes up at 1Gbit. I've tested 4 cables including cat6.
Now testing with a Trend Unipro GbE network tester and get same results.
