Fishbones
Feb 05, 2011Tutor
Ethernet 1 connecting at 100Mbit only.
After a power cycle on a PRO Business eth0 will only connect at 100Mbit. Swapped cables, inspected and cleaned socket but no go. The NAS is connected to a GS108T switch. Log for eth0 after a reco...
Fishbones
Feb 11, 2011Tutor
PapaBear wrote: Have you opened a case with Tech Support?
Yes I have ...Case #14582370 then level 2 with Case#14603314.
See my post above with the latest response.
Cheers.
