Fishbones
Feb 05, 2011Tutor
Ethernet 1 connecting at 100Mbit only.
After a power cycle on a PRO Business eth0 will only connect at 100Mbit. Swapped cables, inspected and cleaned socket but no go. The NAS is connected to a GS108T switch. Log for eth0 after a reco...
orGSD1
Mar 02, 2011Aspirant
Have you tried disabling Jumbo Frames?
I just ran into this issue and trying to figure out why one of the RDNP's was coming up as Gigabit, and the other not, I noticed that the one with 100Mb had Jumbo Frames enabled.
Disabling Jumbo Frames and rebooting brought it back to 1Gbit.
I realize this is almost too simple to solve your problem, as it did mine, and have not yet really investigated why this was the case but I thought I would at least share how it solved my issue, I found your thread while searching for solutions.
Best of luck!
Cheers,
orGSD
Best of luck!
Cheers,
orGSD
