Fishbones
Feb 05, 2011Tutor
Ethernet 1 connecting at 100Mbit only.
After a power cycle on a PRO Business eth0 will only connect at 100Mbit. Swapped cables, inspected and cleaned socket but no go. The NAS is connected to a GS108T switch. Log for eth0 after a reco...
orGSD1
Mar 03, 2011Aspirant
Well, unfortunately, I am in the same boat.
Upon first "connection" it is 1Gbit, but then it falls back to 100Mb after an unknown period of time. I will dig into this further and try replacing every item in the picture, but I now know the jumbo frames was a red herring. It was just that since it went back to 1Gbit upon first connecting after the reboot I thought it was fixed. I noticed that it went back to 100Mbit. Telling it to renew the static DHCP lease brought it back up at 1Gbit. Undoubtedly it will be back at 100Mbit later.
Sorry for the false hope!
Cheers,
orGSD
Cheers,
orGSD
