Fishbones
Feb 05, 2011Tutor
Ethernet 1 connecting at 100Mbit only.
After a power cycle on a PRO Business eth0 will only connect at 100Mbit. Swapped cables, inspected and cleaned socket but no go. The NAS is connected to a GS108T switch. Log for eth0 after a reco...
orGSD1
Mar 05, 2011Aspirant
@Fishbones: Thank you for the short guide. I am in the process of trying it right now but had a quick question. I do not see the purpose of the included photo as it does not seem aligned with what the instructions suggest. It seems to have two fan headers circled only. Am I missing part of your recommendation?
Of minor interest, I see that my CPU fan has 4 wires as opposed to your 3.
Thanks four the help!
Cheers,
orGSD
Cheers,
orGSD
