Fishbones
Feb 05, 2011Tutor
Ethernet 1 connecting at 100Mbit only.
After a power cycle on a PRO Business eth0 will only connect at 100Mbit. Swapped cables, inspected and cleaned socket but no go. The NAS is connected to a GS108T switch. Log for eth0 after a reco...
Fishbones
Mar 06, 2011Tutor
:oops: I should've explained the pic.
This is the only pic I found of the inside of a Pro. It's from a netgear "Service Action for ReadyNAS Pro CPU fan speed control" http://www.readynas.com/?p=1912. Very misleading, sorry.
I have in replaced the pic with the appropriate comments for this fix.
Cheers.
Cheers.
