Fishbones
Feb 05, 2011Tutor
Ethernet 1 connecting at 100Mbit only.
After a power cycle on a PRO Business eth0 will only connect at 100Mbit. Swapped cables, inspected and cleaned socket but no go. The NAS is connected to a GS108T switch. Log for eth0 after a reco...
rysior
Dec 18, 2012Aspirant
Check UTP cable! Some brands provide cheap cable with 4 wires inside (look at RJ45 connector). For gigabit you need 8 wires inside CAT 5e or CAT 6 for longer distance. Check your PC network card and router- it have to be gigabit as well
