Dewdman42
Jul 16, 2025Virtuoso
Factory Reset and some questions
Continuation from other thread about my bad disk(s)... Now that I have factory reset it, it's a bit depressing to realize I lost all kinds of customizations I had made to ReadyNASOS over the cour...
Jul 20, 2025Guru - Experienced User
Dewdman42 wrote:not sure what to make of it, something about key expired?
The debian folks aren't renewing the certs, and they are expiring over time. The overrides in apt.conf are intended to them to be installed anyway (which is why they are warnings).
- Dewdman42Jul 20, 2025Virtuoso
Right, so that explains how I must be getting better action from apt now, as far as non-netgear repos, but I think there is still a problem with netter's repo?
E: The repository 'https://apt.readynas.com/packages/readynasos 6.10.9 Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. W: GPG error: http://archive.kernel.org/debian-archive/debian jessie Release: The following signatures were invali d: KEYEXPIRED 1587841717Also when I try to install build-essential, I get the following error at this point, which makes me wonder if somehow when I did something earlier, some non-netgear version of libc-dev got installed or something, or its not actually trying to fetch from netgear's repo even now....the build-essential, which I seem to recall needs to come from there, but it was a long time when when first set that up on this machine, years and years ago. Can't remember what I did exactly.
root@webman:/home/sjs# apt install build-essential Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: build-essential : Depends: libc6-dev but it is not going to be installed or libc-dev Depends: g++ (>= 4:4.9.1) but it is not going to be installed E: Unable to correct problems, you have held broken packages.I remember seeing another error at some point that said something about me having some netgear version of one library and not compatible with a non-netgear library or something in build-essentials, etc.. I"m not really sure what is wrong or how I can set this up for compiling again...
But anyway after turning off the need to authorize, it did allow nzbget to install correctly and now I was actually able to use apt to install a couple things like python2, so its progress, and the 'apt list' is MUCH much longer after having done that, but somehow I feel I might have earlier installed something when apt was broken, that has now put my libc stuff in a broken state. Any advice or comments about that?
So if I can get python3.5+ on here again like I had before I'd be able to ressurect Medusa also, which would be tremendous. I will either have to compile it, if I can bet build-essential installed and working properly...or...there is someone out that that has a Jessie version of python3.7 in apt repo form, that I might try to install... so..things are looking up to get this back to where I was before, despite deprecation.
have the following working again since factory reset on 6.10.9:
- idrive backup
- shellinbox 2.14
- smbplus
- nzbget (updated to most recent version also)
- python2
- nodejs
- vim (newest from jessie)
- latest plex server
- ncdu
- htop
- iftop
Only other thing I really need to get back to what I was before factory reset, is medusa...which needs python 3.7 for a much more up to date version of medusa compared to the original App Store version I had in there. The App Store installer will setup a frontview icon for starting and stopping it and launching it quickly...but medusa has substantially updated since then, so I basically reinstalled medusa using ssh, but still being controlled by the frontview app control...and it was working great, but Alas, I have to get python 3.7 working in order to do that, and pro ably have to get build-essential working right for that...which I would just like to have back anyway, then I'll be happy camper with current situation as long as the existing apt repos never go away.
Do you know did netgear take down the so called "dev" repo? that's where their version of build-essential was I believe, I need netgear's version of lib6c-dev in particular. It seems this repo is no longer up anywhere...the "dev" section anyway... Maybe I am missing something. I am getting and ERROR related to netgear's repo in general, so not sure if that is relevant or not..but well..might be beating my head against a wall if netgear took away the actual dev packages such as libc6-dev and build-essential.
