abickerton
Sep 11, 2012Aspirant
Factory reset without losing your data.
Full credit to http://home.bott.ca/webserver/?p=306 First retrieve your data. For this you'll need : 1- a sata 2 capable PC. 2- Linux boot disc (CD or USB stick). These instructions are for deb...
abickerton
Sep 12, 2012Aspirant
DSharbaugh . you need to create the directory using "mkdir /tmp/nas-drive"
mdgm - You are correct. It's only known to work with the Sparc Duo. Unfortunately Support couldn't (Wouldn't give timely support) so I needed to try something else.
And yes, this was the last resort. I had already tried and OSA re-install. Sadly that doesn't fix a FUBAR'd disk.
