nulled
Apr 06, 2026Aspirant
Failing ReadyNAS Ultra 4 Plus
I noticed one morning my NAS had powered down and couldn't turn it back on. After turning the power off to it completely and waiting a couple of minutes, it turned back on. Strangely it then turns of...
mrjohno
Apr 08, 2026Aspirant
Sounds like a possible PSU or motherboard issue, especially with random shutdowns and no logs. For data recovery, you’ll likely need to connect all drives to a PC and use a tool like ReclaiMe to rebuild the array. Has anyone confirmed if this model uses a standard RAID layout?
