scion
Sep 18, 2012Aspirant
Fastest way to migrate DUO RND 2150?
My ReadyNAS DUO RND 2150 is RAID 1 and more than 3 years old. I'd like to create a separate backup and keep it offsite. Is there any easy way to 'duplicate' all its contents by migrating one disk to...
scion
Sep 23, 2012Aspirant
Thanks Stephen
Can I just double check my understanding: I can take a hard drive from my existing DUO RND 2150 and put it in a NV+ V1 along with a blank HDD and the NV+ V1 will copy the contents internally on the new blank drive.....? Cool, that sounds a lot faster than transfers over my LAN.
Ion
Ion
