talksr
Jul 29, 2017Aspirant
Faulty ReadyNas Duo RND2120 v2 - Flashing Lights
Hi there, I am having an issue with my RND2120 v2.
When I switch it on,
- Fan is on full speed
- Blue Power light is flashing
- At same time act, drive 1, drive 2 and light above backup button are all flashing (in shape of diamond) at same time as blue power light.
- The nas in question is showing on RAIDar but no firmware version is shown and I am unable to access the admin page or browse to it on the local network.
Assuming there is a firmare or software fault here. Can anyone point me in the right direction. Happy to try using a USB image of software if there are any clear instructions anywhere?
Thanks in advance :cathappy:
- aksVirtuoso
You seem to have no disks instaled, but I think you must have at least one disk for the OS to be installed.
- talksrAspirant
Thanks, ok if I insert a drive, the other lights go off, but the blue one continues to flash. With a drive inserted, the NAS does not show in raidar and I am completely unable to see it or ping it on network.
- aksVirtuoso
Was the inserted drive new/fresh without any partitions? It may be necessary to delete all partitions (in a PC) or force a factory default on the NAS. See these instructions.
