sbircher
Mar 21, 2020Tutor
Files inaccessible after 6.10.3 update on ReadyNas 424
Updated my ReadyNas424 to 10.6.3 now cannot see my files. I can login and see the shares but cannot browse the files. Cannot access from SMB either. I tried on one share to rollback but I get error m...
Mar 21, 2020Guru - Experienced User
sbircher wrote:
I tried on one share to rollback but I get error message code: 28007010000 "Failed to rollback the snapshot. Rollback Snapshot command failed."
Try downloading the full log zip file from the web UI. Look for BTRFS errors in system.log and kernel.log
Don't reboot the system, and don't try rollbacks or other things that update the data volume - your data is at risk, and anything that writes to the RAID array is likely to increase that risk.
Do you have a backup of the files?
sbircher wrote:
I've tried all sorts of ways to contact support but it is impossible. Help please!
Did you try using my.netgear.com
- sbircherMar 21, 2020Tutor
Thanks for the reply. Unfortunateley I think I've got a very old backup but I think its safe to assume I haven't.
I've looked in the log files and in the kernal log I can see the BTRFS errors. I've attached both the logs. I see that in the log summary on the web UI it suggests I have an error and backup the files. I'll try that.
As for the support - yes - I've been through the my.netgear but when I click the purchase button it goes to a page that says "No contracts to dsplay" ???
Here's the system log
- JohnCM_SMar 21, 2020NETGEAR Employee Retired
Hi sbircher,
If you are not able to back up your data, it will be best to contact support so they can check if they can still do corrective changes via backend access or if data recovery is needed.
I can try endorsing you to support so they can assist you, please do note that they might require you to purchase a support contract to be able to assist you. You may just provide me the serial number of your NAS via private message.
