Manuel_Baena
Nov 20, 2018Aspirant
Filesystem still has errors (ReadyNAS 3200)
Hello, I have ReadyNAS 3200 with data volume failures.
After a disk failed, the server restarted and after running automatic checks, it was unable to recover the volume data system.
I put below part of logs messages. Any ideas to recover it? Thanks.
Inode 6074141 is too big. Truncate? yes
Block #656409612 (2845762991) causes directory to be too big. CLEARED.
Block #656409613 (1413754900) causes directory to be too big. CLEARED.
Block #656409614 (710395238) causes directory to be too big. CLEARED.
Block #656409615 (2605083730) causes directory to be too big. CLEARED.
Block #656409616 (627206157) causes directory to be too big. CLEARED.
Block #656409617 (835375234) causes directory to be too big. CLEARED.
Block #656409618 (1721141576) causes directory to be too big. CLEARED.
Inode 6074141 has illegal block(s). Clear? yes
Illegal block #656409619 (4210973595) in inode 6074141. CLEARED.
Error storing directory block information (inode=6074141, block=0, num=200617629): Memory allocation failed
/dev/c/c: ***** FILE SYSTEM WAS MODIFIED *****
e2fsck: aborted
***** File system check performed at Mon Nov 19 09:30:10 CET 2018 *****
fsck 1.42.12 (29-Aug-2014)
/dev/c/c: One or more block group descriptor checksums are invalid. FIXED.
/dev/c/c: Group descriptor 4 checksum is 0x0000, should be 0xf858.
/dev/c/c: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
(i.e., without -a or -p options)
I think you will need data recovery. Netgear has a recovery service here: https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
You could also connect the disks to a Windows PC and try R-Studio for Windows. https://www.r-studio.com/
- Manuel_BaenaAspirant
How can I get int touch with technical support? Through the link (https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service) I don't get any email to contact or other contact form.
my.netgear.com is the place to start for all paid support requests. You don't want Gearhead, you want to go into the registration page and ask for support for your registered ReadyNAS.
