Drunkenspyder
Jan 27, 2020Aspirant
Firmware 6.10.2 w/ Repeated “Bond interface bond0 has slave interface eth2 offline.’ Error messages
I read that this problem was fixed in a previous firmware, but that may not be the case. I left my home for a short trip yesterday, with my 2312 merrily resyncing, and all seeming to go well. I have...
- Jan 31, 2020
schumaku wrote: The 3-4 hash mode is relevant only on the distributed of data leaving the NAS.Yes. The switch would use it's own hash (generally layer-2, and often not configurable).
Since that hash mode was configured on the NAS, it must have been set up as LACP - the other bonding modes don't have that setting. The fact that the bond was working when Drunkenspyder was on-site suggests that the switch must also have been set to LACP.
That leaves three possibilities
- eth2 actually has failed (either cabling or one of the ports)
- the switch rebooted, and the configuration reverted ( as suggested by schumaku )
- Some other firmware glitch in the NAS or switch messed up the bond, and the two devices need to be rebooted.
When you get back I suggest reconfiguring the hash to use layer 2. Layer 3-4 hashing can overrun a gigabit link, and that normally actually hurts your throughput instead of helping it. There are some special cases where it can give a performance boost, but they likely don't apply. And if they did apply, you'd do better using a static LAG on the switch and round-robin on the NAS.
JohnCM_S
Jan 30, 2020NETGEAR Employee Retired
Hi Drunkenspyder,
Usually, when you get that error, you should check first the physical connection between the NAS and the switch.
If everything is fine on the physical connection, you may try deleting and then recreating the bond on the NAS.
