Drunkenspyder
Jan 27, 2020Aspirant
Firmware 6.10.2 w/ Repeated “Bond interface bond0 has slave interface eth2 offline.’ Error messages
I read that this problem was fixed in a previous firmware, but that may not be the case. I left my home for a short trip yesterday, with my 2312 merrily resyncing, and all seeming to go well. I have...
- Jan 31, 2020
schumaku wrote: The 3-4 hash mode is relevant only on the distributed of data leaving the NAS.Yes. The switch would use it's own hash (generally layer-2, and often not configurable).
Since that hash mode was configured on the NAS, it must have been set up as LACP - the other bonding modes don't have that setting. The fact that the bond was working when Drunkenspyder was on-site suggests that the switch must also have been set to LACP.
That leaves three possibilities
- eth2 actually has failed (either cabling or one of the ports)
- the switch rebooted, and the configuration reverted ( as suggested by schumaku )
- Some other firmware glitch in the NAS or switch messed up the bond, and the two devices need to be rebooted.
When you get back I suggest reconfiguring the hash to use layer 2. Layer 3-4 hashing can overrun a gigabit link, and that normally actually hurts your throughput instead of helping it. There are some special cases where it can give a performance boost, but they likely don't apply. And if they did apply, you'd do better using a static LAG on the switch and round-robin on the NAS.
schumaku
Jan 30, 2020Guru - Experienced User
Drunkenspyder wrote:I have a 4-port LAG on my switch for this NAS and the 4-port bond on the 2312 [mode 3-4]
What LAG Teaming Mode? What switch? Some other switch brands require using a [Save] to apply the config on a permenent storage - might be that the switch has rebooted, and the LAG can't compe up. What config of the four ports on the switch side?
- StephenBJan 31, 2020Guru - Experienced User
