mahfooz
May 06, 2017Aspirant
Firmware 6.7.1 Broken my 1 Network Interface and lots of other problems
I have updated my firmware and got following problems
1- It has broken 1 of my network interface.
2- I am unable to see any available apps.
3- I was unable to turn off ready cloud
4- Clicking on firmware give me error message to check internet connection and getting dns communication error
done os reinstall but still same issue
install same firmware again couple of times
I can now able to turn off ready cloud and firmware update is no more having dns and communication issue but still unable to talk through 1 of the NIC and can't see any available apps.
I shouldn't have update my firmware as it was working without any trouble, can i roll it back?
Please help me.
1) How do I point it myself to the correct drive should this happen again ?
1. Create new .apps and home subvolume in new volume, (For example, MyData is new volume)
a. Access NAS via SSH, then run below two commands,
btrfs subvol create /MyData/.apps
btrfs subvol create /MyData/Home
2. /lib/systemd/system/apps.mount and /lib/systemd/system/home.mount were pointing to the NEW volume using vimtiny command, (For example, MyData is new volume in below config)
root@NAS:/# cd /lib/systemd/system
root@NAS:/lib/systemd/system# cat apps.mount
[Unit]
Description=Apps Directory
After=local-fs.target
Before=multi-user.target[Mount]
What=/MyData/.apps
Where=/apps
Type=none
Options=bind[Install]
WantedBy=multi-user.target
root@NAS:/lib/systemd/system# cat home.mount
[Unit]
Description=Home Directory
What=/MyData/home
Where=/home
Type=none
root@NAS:/lib/systemd/system#3. Run OS Reinstall,
2) Should I not use my previous saved config file ? (last time I used this file and it has braked everything again)
You can't restore old config file because mount path is changed, if use old config, it will point to old volume in config file.
- mdgm-ntgrNETGEAR Employee Retired
Please send in your logs (see the Sending Logs link in my sig).
- mahfoozAspirant
Sun May 7 2017 11:37:17 System: Host name was changed to NAS. Sun May 7 2017 11:20:50 System: ReadyNASOS background service started. Sun May 7 2017 11:20:19 System: External storage device connected. Sun May 7 2017 11:20:18 Volume: Less than 5% of volume WDREDNEW's capacity is free. Performance on volume WDREDNEW is degraded. To improve performance, you must add capacity. Sun May 7 2017 11:20:13 Volume: Less than 5% of volume SEAGATE4TB's capacity is free. Performance on volume SEAGATE4TB is degraded. To improve performance, you must add capacity. Sun May 7 2017 11:14:15 System: The system is shutting down. Sun May 7 2017 11:13:47 System: ReadyNAS configuration restored. Reboot this system for the changes to take effect. Sun May 7 2017 11:07:20 System: External storage device connected. Sun May 7 2017 11:06:08 System: ReadyNASOS background service started. Sun May 7 2017 11:05:51 Volume: Less than 5% of volume WDREDNEW's capacity is free. Performance on volume WDREDNEW is degraded. To improve performance, you must add capacity. Sun May 7 2017 11:05:45 Volume: Less than 5% of volume SEAGATE4TB's capacity is free. Performance on volume SEAGATE4TB is degraded. To improve performance, you must add capacity. Sun May 7 2017 10:51:31 System: The system is shutting down. Sun May 7 2017 10:46:43 Account: User 'asad.ae@gmail.com' was deleted. Sun May 7 2017 10:46:40 Account: User 'amahfooz@gmail.com' was deleted. Sun May 7 2017 10:37:14 System: ReadyNASOS background service started. Sun May 7 2017 10:36:53 System: Firmware was upgraded to 6.7.1. Sun May 7 2017 10:36:57 Volume: Less than 5% of volume WDREDNEW's capacity is free. Performance on volume WDREDNEW is degraded. To improve performance, you must add capacity. Sun May 7 2017 10:36:51 Volume: Less than 5% of volume SEAGATE4TB's capacity is free. Performance on volume SEAGATE4TB is degraded. To improve performance, you must add capacity. Sun May 7 2017 10:30:01 System: The system is shutting down. Sun May 7 2017 10:12:46 System: ReadyNASOS background service started. Sun May 7 2017 10:12:10 System: Firmware was upgraded to 6.7.1. Sun May 7 2017 10:12:14 Volume: Less than 5% of volume WDREDNEW's capacity is free. Performance on volume WDREDNEW is degraded. To improve performance, you must add capacity. Sun May 7 2017 10:12:14 System: External storage device connected. Sun May 7 2017 10:12:09 Volume: Less than 5% of volume SEAGATE4TB's capacity is free. Performance on volume SEAGATE4TB is degraded. To improve performance, you must add capacity. Sun May 7 2017 10:06:17 System: The system is rebooting. Sun May 7 2017 9:54:57 System: ReadyNASOS background service started. Sun May 7 2017 9:54:29 Volume: Less than 5% of volume WDREDNEW's capacity is free. Performance on volume WDREDNEW is degraded. To improve performance, you must add capacity. Sun May 7 2017 9:54:29 System: External storage device connected. Sun May 7 2017 9:54:24 Volume: Less than 5% of volume SEAGATE4TB's capacity is free. Performance on volume SEAGATE4TB is degraded. To improve performance, you must add capacity. Sun May 7 2017 9:47:19 System: The system is shutting down. Sun May 7 2017 9:35:29 System: Cannot install application vpnserver. Sun May 7 2017 9:35:24 Share: Share vpnserver was added. Sun May 7 2017 9:30:07 System: ReadyNASOS background service started. Sun May 7 2017 9:29:36 System: External storage device connected. Sun May 7 2017 9:29:36 Volume: Less than 5% of volume WDREDNEW's capacity is free. Performance on volume WDREDNEW is degraded. To improve performance, you must add capacity. Sun May 7 2017 9:29:31 Volume: Less than 5% of volume SEAGATE4TB's capacity is free. Performance on volume SEAGATE4TB is degraded. To improve performance, you must add capacity. Sun May 7 2017 9:25:19 System: The system is rebooting. Sun May 7 2017 8:56:16 System: ReadyNASOS background service started. Sun May 7 2017 8:53:36 Volume: Less than 5% of volume WDREDNEW's capacity is free. Performance on volume WDREDNEW is degraded. To improve performance, you must add capacity. Sun May 7 2017 8:52:33 System: Firmware was upgraded to 6.7.1. Sun May 7 2017 8:52:35 System: External storage device connected. Sun May 7 2017 8:52:30 Volume: Less than 5% of volume SEAGATE4TB's capacity is free. Performance on volume SEAGATE4TB is degraded. To improve performance, you must add capacity. Sun May 7 2017 8:48:34 System: The system is rebooting. Sun May 7 2017 0:05:04 Snapshot: Snapshot prune worker successfully deleted snapshot 2017_04_09__00_00_28 from share or LUN MyData. Sun May 7 2017 0:05:02 Snapshot: Snapshot prune worker successfully deleted snapshot 2017_04_09__00_00_28 from share or LUN KidStuff. Sun May 7 2017 0:00:25 Miscellaneous: Snapshot c_1494072000 was successfully created for share or LUN WD2TB. Sun May 7 2017 0:00:24 Miscellaneous: Snapshot c_1494072000 was successfully created for share or LUN MyData. Sun May 7 2017 0:00:14 Miscellaneous: Snapshot c_1494072000 was successfully created for share or LUN KidStuff. Sat May 6 2017 0:00:29 Miscellaneous: Snapshot c_1493985609 was successfully created for share or LUN WD2TB. Sat May 6 2017 0:00:28 Miscellaneous: Snapshot c_1493985609 was successfully created for share or LUN MyData. Sat May 6 2017 0:00:16 Miscellaneous: Snapshot c_1493985609 was successfully created for share or LUN KidStuff. - mdgm-ntgrNETGEAR Employee Retired
That's the status log. The Sending Logs link in my sig explains how to download the logs and send the zip file in.
From your status log I can see that you have some very full data volumes.
- jak0lantashMentorYou're on a forum. Everyone is welcome to contribute.
You want to talk to NETGEAR Support? Contact NETGEAR Support.
You're angry because you know you messed up, that you shouldn't have restored that config file after somebody fixed your NAS. I get it. But it doesn't give you the right to use bad language.
Hugs and kisses.- mahfoozAspirant
Brother, the way you open your conversation was really ugly and bad and illmanners.
but hi that is fine to yell if no one is listening ...............that's what a normal person do ...................... isn't it......
I am not angry due to I messed up................... I am angry that I was not told to not to do this as it will mess up............2 different scenario if you cable to understand that.
everyone is welcome to contribute but it's a bad manners to take the part when 2 people are talking................unless you will be asked to take the part.............it's just a matter of Manners which I believe not many people have no a days.
Go and try to interfere between when 2 people are having argument and you will not only hear bad language but also get kick as well most of the time.
When someone don't realize that he is getting illmanners than this is how you will try to explain them............using bad language.
Lots of Hugs, Kisses, well wishes and good luck.
- mahfoozAspirant
Still no one there to help me?
