PropTop99
Apr 17, 2017Aspirant
Firmware update still says 'Upgrading'; Moving to FW 6.6.1
I started the Firmware upgrade on the ReadyNAS about an hour ago and RAIDar now shows the unit with a different IP, inaccessible and 'Upgrading'. How long should the process take and what steps S...
PropTop99
I waited for 2Hrs and then had the unit power cycled (it's at a remote location). I ran RAIDar again and I'm still getting the same 'upgrading' message. Any suggestions on what to do or what may be going on??
jak0lantash
Apr 17, 2017Mentor
Are you upgrading to 6.6.1 or from 6.6.1?
- PropTop99Apr 17, 2017Aspirant
I'm not entirely sure. When the Firmware 'Upgrade' popped up on the screen when I logged on, I Ok'd it as it was a good time to get done and didn't think to note the version. Currently, RAIDar shows Status: Upgrading and Firmware under that shows as: 6.6.1
- jak0lantashApr 17, 2017Mentor
F/W 6.7.0 was never available via the auto-update, afaik anyway. So you're probably upgrading to 6.6.1.
Do you what F/W you're coming from though? While it may take some time to update if you were running an old F/W, 2 hours is just too long.
Can you access the GUI now? (partially? does it ask for credentials?)
Is SSH enabled?
Thanks for the Help!
No GUI of any kind coming up and using KiTTY SSH is not connecting on the IP indicated by RAIDar. As for the previous version, I thought I had checked in the near past and it said that there were NO firmware upgrades available. That being the case, I don't know what the previous Firmware version was. :/
