potrero
Jul 12, 2017Aspirant
Firmware Upgrade ReadyNAS NV - from 4.1.6 to latest 4.1.15
Hi - I'm currently running RAIDiator 4.1.6 with four 256GB drives. I'd like to upgrade to four 2TB drives and I understand I need to update my firmware to do so. Questions: 1) Is it OK to jump from...
- Jul 17, 2017
Issues resolved by performing the following:
- followed the steps listed in the first reply.
- used a 500GB approved drive as a scratch disk and updated to latest 4.1.16 firmware
- per steps, installed the 4 2TB WD Caviar black drives with a factory install (successfully loaded 4.1.16 and showed correct updated storage amount).
- had to use Firefox browser on mac to get the proper feature display to update the Alert Message/Email info.
- manually loaded the latest Squeezebox/LMS version (v7.9.0) and copied data back to the drives.
You'll find the LMS installers (Logitech Media Server) for various platforms in http://downloads.slimdevices.com/Log...Server_v7.9.0/.
Marty_M
Jul 16, 2017NETGEAR Employee Retired
Hello potrero,
We’d greatly appreciate hearing your feedback. It does appear the issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
NETGEAR Community Team
potrero
Jul 17, 2017Aspirant
