bobinatcat
Sep 30, 2011Aspirant
Folder Arrangement Issues.
Hi all, I am very new to this but my issue is I run two x Western Digital (2tb) in a ReadyNAS NV+ which is running RAID1. Strange as I selected flexible RAID0 but oh well, it can be reformatte...
sphardy1
Sep 30, 2011Apprentice
That is a "Feature" of DLNA - presenting media of the same type altogether even if it is stored in different folder trees.
Your WD client may have an option to view via folder structure that you can use. Else it can access your NAS via CIFs which should also maintain the folder structure
RAID-0: You can configure as 2 separate volumes, one per disk, or as one large consolidated volume (personally I don't recommend the latter)
RAID-1: one disk mirrors the other
