carlocki's avatar
carlocki
Luminary
Jan 07, 2024
formatting my netgear rn104
I have a full backup on external hdd of my nas rn 104 (just one bcp unfortunately) I need help for this reinstallation and I help someone can follow me trough all of this. My main need it is about ...
  • StephenB's avatar
    Jan 09, 2024
    What happens when you enter this from the Windows CMD line?
    net use * /d /y
    net use t: \\192.168.1.4\data /user:admin nas-admin-password
     using the actual NAS admin password of course.
    It should mount the entire data volume as drive letter T.
    If you are using password as the admin password you'll need to change that before trying the above commands.
    Also, the second command assumes you are using X-RAID - if you aren't, then you need to use the NAS volume name instead of data
ProSupport for Business
