lennart1
Jul 30, 2013Aspirant
From RND2000 to newer model, migrating disks?
How can i migrating the data on disks when u go from a RND2000 to a newer model? Which model should i take? The disks are in a X-RAID2 config.
- lennart1AspirantThe KB states, i can migrate if the architecture is the same
http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
AFAIK my RND2000 has a X86, so i should find a different X86. Ah .. pff are they still available? - mdgm-ntgrNETGEAR Employee RetiredNone of the Duos are x86.
The v2 (which presumably you have if you are using X-RAID2) is ARM.
Newer models use a different filesystem. So you should purchase new disks and transfer your data across your network e.g. using a backup job. - StephenBGuru - Experienced Userlenart - can you confirm your model number? Maybe also post your firmware version, since that will tell us definitively what platform you have.
