dsm1212's avatar
dsm1212
Apprentice
Jan 30, 2021
Full reinit procedure for Pro 6?
Had this Pro6 for years and it's worked great but I finally put together a newer box based on opensource and docker. Since this is still running I want to use it for backups. But there is a bad file on the root partition. I've never been able to fix it because there is no good procedure on readynas to fsck root. Before I start loading it with backups I'd like to reinit the box to fix the root partition. Which reset procedure actually recreates the root partition? It's running 6.10.4 currently and I'm ok with losing all data.
thanks
steve
  • StephenB's avatar
    A factory default will reformat the disks.  Or you can remove the partitions with the NAS powered down - for instance by connecting the disks to a windows PC and deleting them with windows disk manager.  The put them back in the NAS and power up, and it will do a factory install.
    • Sandshark's avatar
      Sandshark
      Sensei
      While a Pro6 running the original 4.2.x RAIDiator OS is still a viable backup, and even a usable main NAS for many, I believe the day will come, perhaps not too far off, that access will be more limited as the protocols used are further depreciated in Windows and browsers and made impossible to enable.  So, since you are going to do a factory default, anyway, this would be a good time to decide if upgrading to OS6 is right for you.
      • StephenB's avatar
        Good general advice, but I think you missed that dsm1212 is already running 6.10.4.
ProSupport for Business
