Draax's avatar
Draax
Harddrive Question
Hello,
I have a question about the harddrives outside the Netgear nas.
Im running raid 1 on 2 drives, is it posible to remove one drive and plug it into my computer to access the data (running windows) if so do i need any software?
Thanks in advance!
  • Awesome, ill replay with the result's thanks a lot in advance!
  • StephenB's avatar
    Shut down the NAS, especially don't hot-insert after you try this. The NAS will wipe the drive and then rebuild the RAID array if you do that.
  • Hello again and thanks for a quick reply.
    I recive an error when i try open "volume 6 (linux RAID partition)" error: Can't open disk: Volume6 RAID partition) Check the disk and try again.
ProSupport for Business
