RonA
Feb 21, 2012Follower
Hardware Compatibility List (HCL) updates please
I have a Pro business ed. and a Ultra4. On the Pro business I need to populate with some bigger disks. We have a mix of Seagate ST33000651AS (3TB), ST3100034oNS (1TB), and WD2003FYYS-02WOB0 (2TB) a...
Flash1
Mar 19, 2012Aspirant
mdgm wrote: For the Infrant ReadyNAS 600A you should use the NV+ (v1) list. Most drives compatible with the NV+ (v1) should be compatible with the 600A. The 600A and NV+ (v1) do not support 3TB drives. 2TB or smaller capacity drives are the ones to use.
mdgm, I appreciate the tip, I'm not looking for new drives for my 600. I just used it as an example that I completely understand Netgear not taking the time to test new drives in an old discontinued product (despite the fact that it still works great)! :D
