Dellagratti
Apr 27, 2016Aspirant
Having serious problem mounting NAS
Im trying to mount the NAS to my PC. Unable to do so. I get this error: Windows sockets registry entries required for network connectivity are missing I have tried to reset netsh and winsock2. Unab...
Apr 28, 2016Guru - Experienced User
If you google "Windows sockets registry entries required for network connectivity are missing" you'll see quite a few windows 10 folks have seen this problem.
Did you try disabling and then re-enabling the windows ethernet adapter?
JennC
Apr 28, 2016NETGEAR Employee Retired
Hello Dellagratti,
This error isn't something about ReadyNAS. This might help: http://answers.microsoft.com/en-us/insider/forum/insider_wintp-insider_web/windows-socket-registry-entries-missing-according/5f54e033-9d49-4de0-bf23-576653641b20?auth=1
Welcome to the community!
- DellagrattiApr 28, 2016Aspirant
I did try all of those steps and not a single one worked. However, I did get it running a little while ago. It was an error that I had overlooked. I had my home network set as public and needed to change it to private. I know...DOH! I had a Homer Simpson moment.
