Valentino1
Feb 10, 2016Aspirant
HD WD 3Tb not accepted
Greetings, So I have a recent WD 3 TB Green Sata 64MB model 30EZRX obviously it is not in the HCL for my ReadyNas 104 (4 bays). The NAS correctly identifies the HD, it is clickable in the web adm...
mdgm-ntgr
Feb 10, 2016NETGEAR Employee Retired
What do the SMART stats of the disk look like?
Valentino1
Thks for quick reply,
How do I check? in Disk utility on the Mac it only shows SMART status: not Supported.
- mdgm-ntgrFeb 10, 2016NETGEAR Employee Retired
With the disk inserted in the NAS you could hover or the disk in RAIDar or better yet download the logs zip file and look in that.
How is the disk connected to your Mac? Is it in an internal sata slot or have you connected it e.g. via USB? It's possible SMART commands may not work with some USB enclosures.- Valentino1Feb 10, 2016Aspirant
Yes I read about the connection issue re USB port and SMART status, It is an internal drive currently connected via USB. I will disconnect place back in NAS and follow your instructions before reporting back.
Thanks
Smart history log shows:
model serial realloc_sect realloc_evnt spin_retry_cnt ioedc cmd_timeouts pending_sect uncorrectable_err ata_errors timestamp time -------------------- -------------------- ------------ ------------ -------------- ---------- ------------ ------------ ----------------- ---------- ---------- -- WDC WD30EZRX-00DC0B0 WD-WMC1XXXXXXXX -1 -1 -1 -1 -1 -1 -1 0 1455166663 2016-02-11 04:57:43 WDC WD30EZRX-00DC0B0 WD-WMC1XXXXXXXX 0 0 0 -1 -1 0 0 0 1455166759 2016-02-11 04:59:19
