Simon__
Jun 05, 2014Aspirant
HDD recommendations for Readynas NV+ v1
I currently have two 1TB Seagate drives (ST31000322CS) which have been in use for 5 years (spin down when not active) and I think are in good health (see below), but I'm running low on space - 192GB f...
Jun 06, 2014Guru - Experienced User
Thx for pointing this out.
markwoll wrote: The red drives including the WD10EFRX are Advanced Format drives ( 4k )
I'd use it anyway though. Otherwise you end up searching for drives no longer in production. Sometimes you can find them, but often the price is way out of line.
If the performance noticeably drops off you would need a reset to restore it. Though you might find it is ok - my NV+ is mis-aligned, and I've never gotten around to fixing it. I use it for backup of my Pro, and its more than fast enough for that.
