Simon__
Jun 05, 2014Aspirant
HDD recommendations for Readynas NV+ v1
I currently have two 1TB Seagate drives (ST31000322CS) which have been in use for 5 years (spin down when not active) and I think are in good health (see below), but I'm running low on space - 192GB f...
belrangodoucet
Aug 12, 2014Aspirant
I`ve recently been looking for HDD replacement/ upgrade to 2TB, and have been finding it difficult to find a good HDD that is on the HCL from retailers. Just about the only thing I see from my regular retailer is a Seagate drive that only has 1 year warranty, and some unflattering reviews ... Unfortunate, since I would typically buy Seagate.
I note your earlier comment on WD10EFRX (which is on the HCL), and note regarding WD20EFRX (which is not on the HCL) for 2TB.
The WD20EFRX is available from my regular retailer, so very much interested in getting this if it is, in fact, supported.
Is this a known omission from the HCL ? Would I be refused support if I got the WD20EFRX ?
Any advice/guidance would be appreciated.
Thanks!
Thanks!
