Simon__
Jun 05, 2014Aspirant
HDD recommendations for Readynas NV+ v1
I currently have two 1TB Seagate drives (ST31000322CS) which have been in use for 5 years (spin down when not active) and I think are in good health (see below), but I'm running low on space - 192GB f...
mdgm-ntgr
Aug 12, 2014NETGEAR Employee Retired
If you do choose to use drives outside the compatibility list you need to be extra vigilant to make sure your backup is up to date in case you run into issues. So you have a backup to restore from if you are unable to get support.
