Simon__
Jun 05, 2014Aspirant
HDD recommendations for Readynas NV+ v1
I currently have two 1TB Seagate drives (ST31000322CS) which have been in use for 5 years (spin down when not active) and I think are in good health (see below), but I'm running low on space - 192GB f...
mad_penguin
Sep 29, 2014Aspirant
StephenB wrote: I've had no issues with the 2 TB Red in the duo v1.
Though I'd suggest you invest a bit in more backup capability. USB drives are not expensive.
Thanks for the confirmation.
6TB USB drivers tends to be on the expensive side ;) I CAN backup critical data (which is way less than that), it's all the "confort" stuff on the side which would be a pain ;)
