Tischnoetentoet
Oct 28, 2014Aspirant
Healthy disk rendered dead
Hello, A few weeks back, my NAS warned me that a disk was dead. I ordered 2 new disks (WD30EFRX) and replaced it. All went fine until today: a new email saying a disk was rendered dead. I thought i...
mdgm-ntgr
Oct 28, 2014NETGEAR Employee Retired
Assuming the new disk is fine, but marked as dead then there could be a problem with the slot. Can you try an extended test of the disk using WD Data LifeGuard Diagnostics?
When did you purchase this NVX? Did you purchase it brand new?
Is it a NVX or a NVX Pioneer?
Yes a factory reset will wipe the disks.
Depends on what the issue is. I guess you could send me your logs first if you like.
