Froberg
Apr 02, 2013Aspirant
Help me with what to purchase.
Hi all, I'm looking at getting a ReadyNAS system, as all my colleagues at work have one - so that seems as good a testimony as any. My current data requirements are; Music: 1.2TB and growing ...
Apr 03, 2013Guru - Experienced User
Netgear's spec says the "typical" noise level is 25 dba @ 1 meter. You will be able to hear it, though it is not too loud. The disks make some of this noise - and the WD 3 TB reds you are considering are very quiet (much better than average). BTW when the unit powers up the fans come on a full speed for a bit, and that is easily heard.
You can probably jury-rig a sound baffle if you found it was objectionable, as long as you keep reasonable airspace around the unit.
