Froberg
Apr 02, 2013Aspirant
Help me with what to purchase.
Hi all, I'm looking at getting a ReadyNAS system, as all my colleagues at work have one - so that seems as good a testimony as any. My current data requirements are; Music: 1.2TB and growing ...
mdgm-ntgr
Apr 03, 2013NETGEAR Employee Retired
Yes, on the 6-bay devices there is a header on the motherboard and you can connect a VGA header cable from the VGA header on the motherboard to the slot at the back of the chassis. You would need to find a VGA header cable with the right connector and the appropriate length or make your own.
