chesirecat1
Sep 08, 2011Aspirant
Help! Repeating RAM Error
Hello, I own an NV+. It had been acting finicky for a few weeks (shutting itself off after a few hours of uptime) and eventually (after a memory test that it never finished) stopped booting, coming...
mdgm-ntgr
Sep 08, 2011NETGEAR Employee Retired
When did you purchase your ReadyNAS? Was it purchased brand new on/after Aug 21, 2007? If so, you could give NetGear a call for assistance with registering your product. The NAS would still be under warranty if this is the case and a RMA of your unit would probably the best way forward.
It's likely your RAM module failed and the new one is incompatible (yes memory manufacturers have changed memory modules rendering them incompatible without changing the module number). 3rd party memory upgrades are not supported. Best to try a memory module that someone has recently purchases and installed successfully in their Duo/NV/NV+.
Welcome to the forum!
