TransientWolf
Apr 01, 2012Aspirant
Help! Ultra 6 or Pro 6
Hi. Welcome some honest advice. I have a Sparc NV which has saved me amazingly well - currently loaded with 4x WD Green drives. Just starting to feel a bit slow when loading up 5gb HD movie files...
Apr 01, 2012Guru - Experienced User
I have a pro.
Both the ultra and the pro are much faster than your NV, so both will meet your application needs. I think you have taken all the technical factors into consideration. The pro has a 5 year warranty, which is one thing you haven't mentioned.
BTW, I recommend using new disks with the new NAS, and shift your backup strategy to use your existing NV.
