TransientWolf
Apr 01, 2012Aspirant
Help! Ultra 6 or Pro 6
Hi. Welcome some honest advice. I have a Sparc NV which has saved me amazingly well - currently loaded with 4x WD Green drives. Just starting to feel a bit slow when loading up 5gb HD movie files...
Apr 02, 2012Guru - Experienced User
I was assuming that the NV was used for primary storage. I agree that what you are already doing is sound.
One benefit of using the Ultra as primary storage is that when you (eventually) replace your Mac Pro you can go with a smaller SSD disk. Just a possibility for the future.
