TransientWolf
Apr 01, 2012Aspirant
Help! Ultra 6 or Pro 6
Hi. Welcome some honest advice. I have a Sparc NV which has saved me amazingly well - currently loaded with 4x WD Green drives. Just starting to feel a bit slow when loading up 5gb HD movie files...
mdgm-ntgr
Apr 02, 2012NETGEAR Employee Retired
CPU in Pro 6 is much faster. See CPU Specs of the ReadyNAS
Transfer speeds for Pro 6 are higher. Unless you need to transcode video (convert video on the fly to a different format) to stream it to your devices you shouldn't need the extra CPU power in the Pro 6.
Pro 6 also has business features such as NIC Teaming.
