TransientWolf
Apr 01, 2012Aspirant
Help! Ultra 6 or Pro 6
Hi. Welcome some honest advice. I have a Sparc NV which has saved me amazingly well - currently loaded with 4x WD Green drives. Just starting to feel a bit slow when loading up 5gb HD movie files...
mdgm-ntgr
Apr 03, 2012NETGEAR Employee Retired
If you can stream from the NV to the Apple TV you'll have no problems streaming the same way using the Ultra.
I have the Ultra 6 (beta tester so received free diskless unit). Personally I'd like to save up and buy a faster unit though the Ultra 6 is a great NAS and works really well.
