bullfrog1
Jul 10, 2013Tutor
How Bricked is this unit - SOLVED - bad memory
Hi I own 5 readynas NV+'s purchased from new, we also have 2100's,NVX's at work. I've taken a risk and purchased a second user 2100. When power is applied the USB and disk 2 lights come on solid an...
mdgm-ntgr
Jul 10, 2013NETGEAR Employee Retired
That testing by the reseller is poor, but pretty typical. Buying second hand is a bit like tossing a coin, sometimes you win and sometimes you lose. It is quite risky. If they sold it to you as is and if you are not protected by laws in your country in this situation then I don't think there's much you can do.
I don't think support would help you with a system purchased second hand.
You could perhaps check if installing a different memory module with the same specs allows the NAS to boot further.
