bullfrog1
Jul 10, 2013Tutor
How Bricked is this unit - SOLVED - bad memory
Hi I own 5 readynas NV+'s purchased from new, we also have 2100's,NVX's at work. I've taken a risk and purchased a second user 2100. When power is applied the USB and disk 2 lights come on solid an...
Marto731
Jul 10, 2013Aspirant
To Bullfrog,
Can I ask that you insert a single blank disk and Factory reset.
Does RAIDar find the NAS? Can you ping it?
If not, then 2100 chassis is 'bricked'. As a 2nd hand unit, it would not be covered
by warranty.
Regards, Marto
by warranty.
Regards, Marto
