bullfrog1
Jul 10, 2013Tutor
How Bricked is this unit - SOLVED - bad memory
Hi I own 5 readynas NV+'s purchased from new, we also have 2100's,NVX's at work. I've taken a risk and purchased a second user 2100. When power is applied the USB and disk 2 lights come on solid an...
bullfrog1
Jul 19, 2013Tutor
Hi
Just bringing you up to speed. I had a readynas NVX kicking around , I was able to borrow the SO Dimm from it, it's the same make/part number as the one in the 2100. The 2100 boots successfully.
Tried again with original SO Dimm , same fault code on the front. Incidentally with no SO Dimm fitted this is the same fault code.
So result - well happy. New Dimm ordered.
If USB and Drive 2 lights are stuck on with all other lights off with blue power light flashing, with no other response from switch on, suspect duff or missing SO Dimm in a readynas 2100. Perhaps someone could update the FAQ's so that this sequence is recorded somewhere more accessible.
Thanks to mdgm for his help.
mdgm 1 tech support nill
Bullfrog
Bullfrog
