bullfrog1
Jul 10, 2013Tutor
How Bricked is this unit - SOLVED - bad memory
Hi I own 5 readynas NV+'s purchased from new, we also have 2100's,NVX's at work. I've taken a risk and purchased a second user 2100. When power is applied the USB and disk 2 lights come on solid an...
mdgm-ntgr
Jul 19, 2013NETGEAR Employee Retired
It just goes to show that if the NAS is getting stuck in the BIOS boot process that it is worth checking the memory.
The NVX, 1500 and 2100v1 all use very similar CPUs. So it's not surprising that they would use the same memory.
