bullfrog1
Jul 10, 2013Tutor
How Bricked is this unit - SOLVED - bad memory
Hi I own 5 readynas NV+'s purchased from new, we also have 2100's,NVX's at work. I've taken a risk and purchased a second user 2100. When power is applied the USB and disk 2 lights come on solid an...
bullfrog1
Jul 31, 2013Tutor
mdgm wrote: This thread may be of help: http://www.readynas.com/forum/viewtopic.php?f=24&t=70272
Doesn't appear to be any answers in this thread only 2 posts.
mdgm wrote: Can you download the logs (Status > Logs > Download all Logs) and confirm the CPU model that is in your NAS?
According to the kernel.log
Dec 31 16:30:54 nas-C0-C2-DA kernel: CPU0: Intel(R) Atom(TM) CPU D510 @ 1.66GHz stepping 0a
mdgm wrote: You can change your forum password. See User Control Panel > Profile > Edit Account Settings
Clearly old age is creeping in - couldn't see User control Panel until you mentioned it.
Thanks
Bullfrog
